[#7]
Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@] SKOLMAN_MWS ˇ agrEssOr [,
post #6
Hi Skolman ! Thanks for answer ! (my mail is suck as i can see.. well, i send to you new mail addr now).
btw, i setup amigg,it is not so hard for me talk in polish, becouse i am russian, but hard anyway. I can setup it, and added you for me, but you offline around 20-30 hours for me :) (or maybe i sleep in this time when you coming).
Anyway. I try to test this stuff for other bvision too, and have the same rezult. All is work, but colours is ugly and the same screenshot !
I am not use permedia libs .. only Warp3d.library. But, maybe i do in code somethink, thank can do only voodoo ? i mean warp3d.library watch that i can do W3D_SetState(somethink) for example, and try to open permedia libs .. Or maybe for bvision it is try to open some unused directory for tests .. Like 'if not permedia for this driver, so it is bvisoin'
Anyway, i do not do anythink 'great' in code, as i said - it is pure tests. But thank very much for it.. And if you have some more time, we can talk in Amigg by online, and can found where is problem (becouse i want to support voodoo/bvision as minimum, but mos/aos4 good be too).
So, i write you new mail.
