; $VER: Startup-Sequence_HardDrive 40.2 (25.2.93) ; Startup-Sequence for hard drive systems C:SetPatch QUIET C:Version >NIL: C:AddBuffers >NIL: DF0: 15 FailAt 21 C:MakeDir RAM:T RAM:Clipboards RAM:ENV RAM:ENV/Sys C:Copy >NIL: ENVARC: RAM:ENV ALL NOREQ Resident >NIL: C:Assign PURE Resident >NIL: C:Execute PURE Assign >NIL: ENV: RAM:ENV run >nil: C:MagicWB-Demon 4,123,123,123 5,175,175,175 6,170,144,124 7,255,169,151 8,0,0,255 ; Don't remove this entry! Assign >NIL: T: RAM:T Assign >NIL: CLIPS: RAM:Clipboards Assign >NIL: REXX: S: Assign >NIL: PRINTERS: DEVS:Printers Assign >NIL: KEYMAPS: DEVS:Keymaps Assign >NIL: LOCALE: SYS:Locale Assign >NIL: LIBS: SYS:Classes ADD Assign >NIL: HELP: LOCALE:Help DEFER
@qntos, post #1
@cholok, post #6
; $VER: Startup-Sequence_HardDrive 40.2 (25.2.93) ; Startup-Sequence for hard drive systems C:SetPatch QUIET C:Version >NIL: C:AddBuffers >NIL: DF0: 15 FailAt 21 C:MakeDir RAM:T RAM:Clipboards RAM:ENV RAM:ENV/Sys C:Copy >NIL: ENVARC: RAM:ENV ALL NOREQ Resident >NIL: C:Assign PURE Resident >NIL: C:Execute PURE Assign >NIL: ENV: RAM:ENV run >nil: C:MagicWB-Demon 4,123,123,123 5,175,175,175 6,170,144,124 7,255,169,151 8,0,0,255 ; Don't remove this entry! Assign >NIL: T: RAM:T Assign >NIL: CLIPS: RAM:Clipboards Assign >NIL: REXX: S: Assign >NIL: PRINTERS: DEVS:Printers Assign >NIL: KEYMAPS: DEVS:Keymaps Assign >NIL: LOCALE: SYS:Locale Assign >NIL: LIBS: SYS:Classes ADD Assign >NIL: HELP: LOCALE:Help DEFER BindDrivers C:Mount >NIL: DEVS:DOSDrivers/~(#?.info) IF EXISTS DEVS:Monitors IF EXISTS DEVS:Monitors/VGAOnly DEVS:Monitors/VGAOnly EndIF C:List >NIL: DEVS:Monitors/~(#?.info|VGAOnly) TO T:M LFORMAT "DEVS:Monitors/%s" Execute T:M C:Delete >NIL: T:M EndIF SetEnv Language "english" SetEnv Workbench $Workbench SetEnv Kickstart $Kickstart UnSet Workbench UnSet Kickstart C:AddDataTypes REFRESH QUIET C:IPrefs C:ConClip Path >NIL: RAM: C: SYS:Utilities SYS:Rexxc SYS:System S: SYS:Prefs SYS:WBStartup SYS:Tools SYS:Tools/Commodities IF EXISTS S:User-Startup Execute S:User-Startup EndIF Resident Execute REMOVE Resident Assign REMOVE C:LoadWB EndCLI >NIL:
@qntos, post #7
@Norbert, post #10
@qntos, post #11
@qntos, post #13
@Norbert, post #16
@Norbert, post #16
